What cpu usage are you seeing in the Xcode profiler alone i.e. without fmod studio attached ?
( if that’s what you are doing - can’t say since i’ve never used fmod studio profiler )
Its quite possible the CPU has lowered itself into a very low CPU speed as not much else is happening, this is not an FMOD specific issue. If you can put it into a developer mode where the cpu is running at full capacity you will notice this is not going to be anywhere near this high.
