I am trying to create a DSP network of the following form.
1 Input
2 | Apply effect on signal
| 3 Analyze signal for other purposes
4 Output
As you can see DSP 3 is not connected to the output. This is because I am not interested in its result for the output, I am simply using it to process the signal in real time and extract some information.
However when I set up such network in FMOD, DSP 3 is not played at all, and does not show in the profiler.
Is there any way to create branches in the DSP network that are not connected to the output but still processed?
Thanks in advance.
