How to add Fmod Event to a Sequence?
I’m unable to add FMOD events in the sequence, I can only add CUE and waveform… is there a way of triggering FMOD Events inside a sequence ?
regards
Lukas
There is a section for Sequence Integration in the docs.
Or are you running into any errors or warnings?
Thanks, I was adding in but not making it play. Now it works. Thanks a lot!
