How to change default Bank .ogg compression quality?
Hi, when I make new banks it defaults them to .ogg (which is fine) and 37% Quality — which seems oddly low.
Any way to change that default? And is there a reason why 37% is the default? My understanding is the % roughly maps to .ogg’s own 1-10 quality.
The creators of the vorbis codec consider quality 5 to be undetectable, and recommend quality 3 as the best balance between fidelity and size.
There’s no way to change the default in 1.7. However 1.8 has a newer workflow which includes setting defaults.
Ah, thank you Nicholas! Will test. I wasn’t aware of that.
Which 1.8 are you referring to? I’m on FMOD Studio 1.07.06.
1.08.00 which will be released in a month or so.
Now we could adjust the quality, how much % is equivalent to quality 5?
Thank you!
The FMOD range is from 0 to 100, the Vorbis range is from -0.1 to 1.0.
The formula we use to convert between them is:
Vorbis_Quality = ((FMOD_Quality - 1) / 90.0f) - 0.1f;
So for quality 5 (or 0.5 as it is used in the Vorbis API) you need FMOD quality 55.
Thank you!
:smile:
