Hello everyone. I want to make the engine sound in FMOD, for this I found a full-fledged recording of how the engine spins from 2 to 7k rpm. However, in order for the sound to continue all the time, you need to set a repeat, which means it repeats completely again. Is there any way to make the sound play permanently only in the segment where I hold the cursor?
Check the Examples.fspro project bundled with the FMOD Studio software, under Veichles/Car Engine in the Events tab.
You should be able to splice your engine sounds into segments and have it loop using logic tracks and a parameter.
Thanks, i’ll give it a try!
