How to spot empty/null EventReference?
Hi there! I’m using a public FMODUnity.EventReference to hold reference to a sound, but I’m leaving the path empty since I dont have the sound yet.
I’m trying to not call it if it’s null by calling EventReference.IsNull but, it returns not-null. The path is empty on my Unity Editor, but Debug.Log returns a GUID for this EventReference, so it’s not-null.
Is something I’m missing?
A check you could use is
if (reference.Path.Length > 0)
    Debug.Log("Path");
else
    Debug.Log("No path");
Hi Connor, thanks for the reply!
I’m not exactly sure if it would work, since the Path value is not used outside the Unity Editor, right?
No worries,
This is just checking if the Event Path is left empty in the Unity Editor
public FMODUnity.EventReference reference;
void Start()
        Debug.Log("Path");
    else
The script will just need a reference to the Event Reference.
This works only in the editor, how do you check at runtime if an EventReference is null?
An alternative could be using EventReference.isNull.
