I build on the ios platform, I see a lot of Fmod related log information in Xcode,How can I clear it?Where can I close it? And does it affect me?
The Fmod version is 2.00.08.
[LOG] System::create : Header version = 2.00.08. Current version = 2.00.08.
[LOG] SystemI::setOutputInternal : Setting output to ‘FMOD Core Audio Output’
[LOG] Manager::init : maxchannels = 128 studioflags = 00000008 flags 00000000 extradriverdata 0x0.
[LOG] SystemI::init : Initialize version=20008 (108014), maxchannels=128, flags=0x00020000
[LOG] OutputCoreAudio::init : Hardware buffer size: 1024 samples, hardware sample rate: 48000Hz, hardware channels: 2
[LOG] OutputCoreAudio::init : Maximum hardware read size: 4096 samples, Software buffer size: 512 samples, Number of software buffers: 4.
[WRN] OutputCoreAudio::init : DSP buffer size * DSP num buffers is potentially too small.
[WRN] SystemI::init : Output requires a sample rate of 48000Hz, resampling will occur.
[LOG] Thread::initThread : Init FMOD stream thread. Priority: 2, Stack Size: 98304, Semaphore: No, Sleep Time: 10, Looping: Yes.
[LOG] SystemI::DSPCodecPoolRegister : register codec pool for pool type 7
[LOG] Thread::initThread : Init FMOD mixer thread. Priority: 1, Stack Size: 81920, Semaphore: Yes, Sleep Time: 0, Looping: Yes.
[LOG] AsyncManager::init : manager 0x110886208 isAsync 1 updatePeriod 0.02
[LOG] Thread::initThread : Init FMOD Studio update thread. Priority: 0, Stack Size: 98304, Semaphore: No, Sleep Time: 1, Looping: No.
[LOG] AsyncManager::init : done
[LOG] PlaybackSystem::init :
[LOG] Thread::initThread : Init FMOD Studio sample load thread. Priority: 0, Stack Size: 98304, Semaphore: No, Sleep Time: 1, Looping: No.
[LOG] PlaybackSystem::init : done
[LOG] Thread::initThread : Init FMOD Studio bank load thread. Priority: 0, Stack Size: 98304, Semaphore: No, Sleep Time: 1, Looping: No.
[LOG] Manager::init : done.
[LOG] Manager::readBank : fileversion = 125, compatVersion = 119 (oldest = 44, newest = 125)
[LOG] PlaybackSystem::acquireMasterBus : Setting master channel group format to 6
swiftMethod(_
is called with message: GCCtrlSuptBridge Init
2020-03-25 16:13:20.728600+0800 pascalswager[2646:4766614] 16:13:20.728-1: Init lua state cost: 0.02173615
[LOG] SoundI::release : Object_bonfire_ground (0x126658a68)
[LOG] SoundI::release : Object_bonfire_ground (0x1308537b8)
[LOG] SoundI::release : Object_bonfire_ground (0x130808128)
[LOG] SoundI::release : Object_bonfire_wall (0x132b293c8)
[LOG] SoundI::release : Object_bonfire_wall (0x130cb1988)
[LOG] SoundI::release : Object_bonfire_wall (0x130cb1ca8)
[LOG] SoundI::release : Object_bonfire_wall (0x126680408)
[LOG] SoundI::release : Object_bonfire_wall (0x130c1bf18)
[LOG] SoundI::release : Object_bonfire_wall (0x1223c39f8)
[LOG] SoundI::release : Object_bonfire_wall (0x1266670d8)
[LOG] SoundI::release : Object_bonfire_wall (0x132e19878)
[LOG] SoundI::release : Object_bonfire_wall (0x12115c248)
[LOG] SoundI::release : Object_bonfire_wall (0x13c02bfc8)
[LOG] SoundI::release : Object_bonfire_wall (0x1211493c8)
[LOG] SoundI::release : Object_bonfire_wall (0x1211bcc88)
[LOG] SoundI::release : Object_bonfire_wall (0x126668968)
[LOG] SoundI::release : Object_bonfire_wall (0x1211be698)
[LOG] SoundI::release : Object_bonfire_wall (0x1211525a8)
[LOG] SoundI::release : Object_bonfire_wall (0x1266572e8)
[LOG] SoundI::release : Object_bonfire_wall (0x121154bb8)
[LOG] SoundI::release : Object_bonfire_wall (0x1211561a8)
[LOG] SoundI::release : Object_bonfire_wall (0x126659ae8)
[LOG] SoundI::release : Object_bonfire_wall (0x1211557b8)
[LOG] SoundI::release : Object_bonfire_wall (0x121154fa8)
[LOG] SoundI::release : Object_bonfire_wall (0x126653e58)
[LOG] SoundI::release : Object_bonfire_wall (0x130cae168)
[LOG] SoundI::release : Object_bonfire_wall (0x130cae2f8)
[LOG] SoundI::release : Object_bonfire_wall (0x126650278)
[LOG] SoundI::release : Object_bonfire_wall (0x130caebe8)
[LOG] SoundI::release : Object_bonfire_wall (0x130caed78)
[LOG] SoundI::release : Object_bonfire_wall (0x132bbce78)
[LOG] SoundI::release : Object_bonfire_wall (0x130cb4038)
[LOG] SoundI::release : Object_bonfire_wall (0x130cb1228)
[LOG] SoundI::release : Object_altar (0x132baf478)
[LOG] SoundI::release : Object_altar (0x130cb35b8)
[LOG] SoundI::release : Object_altar (0x130cb3748)
[LOG] SoundI::release : Object_altar (0x132ba7bb8)
[LOG] SoundI::release : Object_altar (0x130cb2b38)
[LOG] SoundI::release : Object_altar (0x130cb2cc8)
[LOG] SoundI::release : Object_altar (0x126655ed8)
[LOG] SoundI::release : Object_altar (0x1308c1d78)
[LOG] SoundI::release : Object_altar (0x1308813e8)
[LOG] SoundI::release : Object_bonfire_ground (0x12665ca58)
[LOG] SoundI::release : Object_bonfire_ground (0x13081d098)
[LOG] SoundI::release : Object_bonfire_ground (0x130825928)
