Increase Buses in increments in UE4
Hi
I would like to be able to use a key input in UE4 to increase and decrease the volume of an FMOD bus in stages - ie: press Q to increase 1dB, and A to decrease 1dB.
In UE4 there is a node available for non FMOD events, but i cant seem to replicate this using FMOD
Any ideas?
Thanks
There are nodes available for controlling volumes: BusSetVolume and FMODAudioComponent->SetVolume are a couple.
These both take in a float value for the percent of volume to use, 100% being the volume set in Studio.
Thanks for the response
What i’m actually trying to do is increase the volume by a certain amount on each press – not set it at a specific volume (95% etc) – i would like it to increase an amount/percentage each time.
I guess i could program in each preset level, but was wondering if there is an easier way to do this?
esentially im trying to do this, but with an FMOD event!
https://1drv.ms/i/s!Ak_EnkWP9ZbbgwSF76OrmAnKwkCt
Here is a quick blueprint I put together: http://imgur.com/jAQbkPk
When you press β€œO” it will increase the value of the multiplier then pass that to the FMODAudioComponent. Then when you press β€œL” it will decrease, if the multiplier is greater than zero.
If you wanted to use dB instead of percentage, you would have to add a bit more math to the blueprint as the SetVolume functions only work on percentage of volume set in Studio.
Thank you Cameron, i will have a play with this, but looks very useful
Thanks again
