We recommend using FMOD Studio exclusively for audio, however it is possible to play inbuilt UE4 audio side-by-side. The inbuilt UE4 audio doesn’t go through FMOD Studio mix bus heirarchy, so it isn’t able to be controlled from the mix.
There is a workaround for controlling just the volume of the inbuilt UE4 audio based on a bus volume in FMOD Studio. By applying snapshots to that bus, the following example code will take that volume and apply it into a UE4 SoundMix object.
Then we have two functions, one that must be called at startup, and once per tick:
/** Must be called at startup */
UFUNCTION(BlueprintCallable, Category="Game")
void InitSoundMix();
/** Must be called per tick */
void UpdateSoundMix();
The Init function tries to look up the FMOD bus. It also applies a duplicate of the SoundMix that has been assigned into this actor:
void AExampleGameMode::InitSoundMix()
RuntimeSoundMix = nullptr;
RuntimeSoundMixBus = nullptr;
if (!SoundMix || !SoundMixBus)
// Not set up
return;
// Find bus by ID
FMOD::Studio::System* System = IFMODStudioModule::Get().GetStudioSystem(EFMODSystemContext::Runtime);
FMOD::Studio::ID Guid = FMODUtils::ConvertGuid(SoundMixBus->AssetGuid);
System->getBusByID(&Guid, &RuntimeSoundMixBus);
if (RuntimeSoundMixBus)
RuntimeSoundMixBus->lockChannelGroup(); // Keep bus alive to query underlying channel group
// Init mix modifier
if (GEngine && GEngine->UseSound())
if (FAudioDevice* AudioDevice = GetWorld()->GetAudioDevice())
RuntimeSoundMix = DuplicateObject(SoundMix, nullptr);
AudioDevice->PushSoundMixModifier(RuntimeSoundMix);
The update function tries to get the audibility of the FMOD bus and applies it to each of the sound classes defined for the SoundMix:
void AExampleGameMode::UpdateSoundMix()
float Volume = 1.0f;
// Query effective volume of the bus
FMOD::ChannelGroup* RuntimeGroup = nullptr;
RuntimeSoundMixBus->getChannelGroup(&RuntimeGroup);
if (RuntimeGroup)
RuntimeGroup->getAudibility(&Volume);
// Assign into the UE4 sound mix object
if (RuntimeSoundMix)
for(FSoundClassAdjuster& Adjust : RuntimeSoundMix->SoundClassEffects)
Adjust.VolumeAdjuster = Volume;
To use this code, the actor will need to be set up with an appropriate UE4 SoundMix and a FMOD Bus assigned into the blueprint-accessable fields.
