UM1
September 16, 2022, 6:20am
1
Hi.
We would like to ask you about changing FMOD_CHANNEL ORDER from FMOD_CHANNEL ORDER_DEFAULT to FMOD_CHANNELOR_WAVEFORMAT because the speaker configuration we think is different.
https://www.fmod.com/docs/2.02/api/core-api-common.html#fmod_channelorder
I would like to ask you where I can modify FMOD_CHANNELORDER.
If we proceed with the modification with FMOD_CHANNELORDER_WAVEFORMAT, we would like to ask you when we need to modify it.
Thank you.
UM1:
You can change FMOD_CHANNELORDER when creating a sound with System::createSound , by setting the channelorder in the FMOD_CREATESOUNDEXINFO exinfo struct.
UM1:
FMOD_CHANNELORDER_WAVEFORMAT is for internal use only and will not work with exinfo. If you want to match the speaker layout of FMOD_CHANNELORDER_WAVEFORMAT then you can use a Channel Mix dsp to assign each input channel to an output channel/speaker of your choosing.
