This sound created with Adobe Audition CC - https://dl.dropboxusercontent.com/u/3571256/test-sound.wav will trigger FMOD_CHANNELCONTROL_CALLBACK_END twice. Once immediately on playback and then a second time when the sound ends.
Expectation would be FMOD_CHANNELCONTROL_CALLBACK_END is only called when the sound finishes.
I have replicated the issue using the play_sound example project and changing the button 1 action to look like:
if (Common_BtnPress(BTN_ACTION1))
result = system->playSound(sound1, 0, false, &channel);
channel->setCallback((FMOD_CHANNELCONTROL_CALLBACK)&ChannelControlCallback);
ERRCHECK(result);
and then adding the callback
static FMOD_RESULT F_CALLBACK ChannelControlCallback(FMOD_CHANNEL *channel,
FMOD_CHANNELCONTROL_CALLBACK_TYPE type,
unsigned int commanddata1,
unsigned int commanddata2) {
if (type == FMOD_CHANNELCONTROL_CALLBACK_END) {
printf("ChannelControlCallback: Sound finished\n");
return FMOD_OK;
When playing test-sound.wav I see “ChannelControlCallback: Sound finished” twice. When playing drumloop.wav I only see it once (when the sound actually finishes).
