I’m working on an OSX/IOS application using c++11.
However, when i try to compile the IOS Simulator version, it can’t link against libfmodstudio_iphonesimulator.a because of a problem related to the used c++ library implementation.
It seems that libfmodstudio_iphonesimulator.a needs to link against libstdc++ while my application needs libc++.
How can i deal with that ?
The OSX version compiles successfully.
Thanks.
Here is the errors :
Undefined symbols for architecture i386:
"std::_Rb_tree_decrement(std::_Rb_tree_node_base*)", referenced from:
std::_Rb_tree<FMOD::ID<FMOD::VCAModel>, std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*>, std::_Select1st<std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*> >, std::less<FMOD::ID<FMOD::VCAModel> >, FMOD::Allocator<std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*> >, std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*> const&)
std::_Rb_tree<FMOD::ID<FMOD::VCAModel>, std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*>, std::_Select1st<std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*> >, std::less<FMOD::ID<FMOD::VCAModel> >, FMOD::Allocator<std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*> > >::_M_insert_unique(std::pair<FMOD::ID<FMOD::VCAModel> const, FMOD::VCAInstanceContainer*> const&)
std::_Rb_tree<int, std::pair<int const, FMOD::VCAInstance*>, std::_Select1st<std::pair<int const, FMOD::VCAInstance*> >, std::less<int>, FMOD::Allocator<std::pair<int const, FMOD::VCAInstance*> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<int const, FMOD::VCAInstance*> >, std::pair<int const, FMOD::VCAInstance*> const&)
std::_Rb_tree<int, std::pair<int const, FMOD::VCAInstance*>, std::_Select1st<std::pair<int const, FMOD::VCAInstance*> >, std::less<int>, FMOD::Allocator<std::pair<int const, FMOD::VCAInstance*> > >::_M_insert_unique(std::pair<int const, FMOD::VCAInstance*> const&)
std::_Rb_tree<FMOD::ID<FMOD::EffectModel>, std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*>, std::_Select1st<std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*> >, std::less<FMOD::ID<FMOD::EffectModel> >, FMOD::Allocator<std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*> >, std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*> const&)
std::_Rb_tree<FMOD::ID<FMOD::EffectModel>, std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*>, std::_Select1st<std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*> >, std::less<FMOD::ID<FMOD::EffectModel> >, FMOD::Allocator<std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*> > >::_M_insert_unique(std::pair<FMOD::ID<FMOD::EffectModel> const, FMOD::EffectInstanceContainer*> const&)
std::_Rb_tree<int, std::pair<int const, FMOD::EffectInstance*>, std::_Select1st<std::pair<int const, FMOD::EffectInstance*> >, std::less<int>, FMOD::Allocator<std::pair<int const, FMOD::EffectInstance*> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<int const, FMOD::EffectInstance*> >, std::pair<int const, FMOD::EffectInstance*> const&)
"std::_Rb_tree_increment(std::_Rb_tree_node_base const*)", referenced from:
FMOD::RuntimeAPI::Manager::fixUpSendReturns(FMOD::ObjectLookup*, FMOD::BasicRepository<FMOD::EffectModel, FMOD::SendEffectModel> const&)
FMOD::RuntimeAPI::Manager::fixUpSideChainTargets(FMOD::ObjectLookup*, FMOD::BasicRepository<FMOD::EffectModel, FMOD::SideChainEffectModel> const&)
FMOD::RuntimeAPI::Manager::fixUpVCAStrips(FMOD::ObjectLookup*, FMOD::BasicRepository<FMOD::VCAModel, FMOD::VCAModel> const&)
FMOD::RuntimeAPI::Manager::fixUpEventChildren(FMOD::ObjectLookup*, FMOD::BasicRepository<FMOD::EventModel, FMOD::EventModel> const&)
FMOD::RuntimeAPI::Manager::validateModelRelationships(FMOD::RuntimeAPI::ObjectMissingCallbackInterface*)
FMOD::RuntimeAPI::Manager::lookupGUID(char const*, FMOD_GUID*) const
void FMOD::RuntimeAPI::updateHashForRepository<FMOD::BasicRepository<FMOD::BusModel, FMOD::InputBusModel> >(FMOD::MD5Hash*, FMOD::BasicRepository<FMOD::BusModel, FMOD::InputBusModel> const&)
"std::_Rb_tree_increment(std::_Rb_tree_node_base*)", referenced from:
std::_Rb_tree<FMOD::ID<FMOD::BusModel>, std::pair<FMOD::ID<FMOD::BusModel> const, FMOD::BusInstanceContainer*>, std::_Select1st<std::pair<FMOD::ID<FMOD::BusModel> const, FMOD::BusInstanceContainer*> >, std::less<FMOD::ID<FMOD::BusModel> >, FMOD::Allocator<std::pair<FMOD::ID<FMOD::BusModel> const, FMOD::BusInstanceContainer*> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<FMOD::ID<FMOD::BusModel> const, FMOD::BusInstanceContainer*> >, std::pair<FMOD::ID<FMOD::BusModel> const, FMOD::BusInstanceContainer*> const&)
std::_Rb_tree<int, std::pair<int const, FMOD::BusInstance*>, std::_Select1st<std::pair<int const, FMOD::BusInstance*> >, std::less<int>, FMOD::Allocator<std::pair<int const, FMOD::BusInstance*> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<int const, FMOD::BusInstance*> >, std::pair<int const, FMOD::BusInstance*> const&)
std::_Rb_tree<FMOD::ID<FMOD::EventModel>, std::pair<FMOD::ID<FMOD::EventModel> const, FMOD::EventInstanceContainer*>, std::_Select1st<std::pair<FMOD::ID<FMOD::EventModel> const, FMOD::EventInstanceContainer*> >, std::less<FMOD::ID<FMOD::EventModel> >, FMOD::Allocator<std::pair<FMOD::ID<FMOD::EventModel> const, FMOD::EventInstanceContainer*> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<FMOD::ID<FMOD::EventModel> const, FMOD::EventInstanceContainer*> >, std::pair<FMOD::ID<FMOD::EventModel> const, FMOD::EventInstanceContainer*> const&)
"std::_Rb_tree_rebalance_for_erase(std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)", referenced from:
FMOD::FMODMap<FMOD::ID<FMOD::EventModel>, FMOD::EventInstanceContainer*>::remove(FMOD::ID<FMOD::EventModel> const&)
FMOD::FMODMap<FMOD::ID<FMOD::BusModel>, FMOD::BusInstanceContainer*>::remove(FMOD::ID<FMOD::BusModel> const&)
FMOD::FMODMap<FMOD::ID<FMOD::EffectModel>, FMOD::EffectInstanceContainer*>::remove(FMOD::ID<FMOD::EffectModel> const&)
FMOD::FMODMap<FMOD::ID<FMOD::VCAModel>, FMOD::VCAInstanceContainer*>::remove(FMOD::ID<FMOD::VCAModel> const&)
FMOD::FMODMap<int, FMOD::VCAInstance*>::move(int const&, FMOD::FMODMap<int, FMOD::VCAInstance*>*)
FMOD::FMODMap<FMOD::ID<FMOD::VCAModel>, FMOD::VCAInstanceContainer*>::move(FMOD::ID<FMOD::VCAModel> const&, FMOD::FMODMap<FMOD::ID<FMOD::VCAModel>, FMOD::VCAInstanceContainer*>*)
FMOD::FMODMap<int, FMOD::EffectInstance*>::move(int const&, FMOD::FMODMap<int, FMOD::EffectInstance*>*)
"std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)", referenced from:
ld: symbol(s) not found for architecture i386
clang: error: linker command failed with exit code 1 (use -v to see invocation)
15ff9msf]
