linking with MinGW g++ 64bit on win7
i read a lot postings regarding linking issues with mingw and also a lot of workarounds. But the official statement is, that i should be able to use fmod also in mingw. I am using
fmodstudioapi10607win-installer
What have i done to test this so far?
  1. I copied the play_stream.cpp, common.h and common_platform.h into a testfolder
  2. changed the function name to
    int main(int argc, char **argv)
  3. copied all .h and .hpp from the inc-folder to c:\fmod\inc
  4. copied fmod64.dll from the lib-folder to c:\fmod\lib
  5. created a make-file
INCLUDE_PATH = -Ic:/fmod/inc
LIBRARY_PATH = -Lc:/fmod/lib/
LIBS = -lfmod64
all: play_stream.cpp
g++ -std=c++11 play_stream.cpp -o play_stream $(INCLUDE_PATH) $(LIBRARY_PATH) $(LIBS)
But when i compile (and link) i get a lot of undefined reference like:
play_stream.cpp:(.text+0x31): undefined reference to `Common_Init(void**)'
play_stream.cpp:(.text+0x57): undefined reference to `ERRCHECK_fn(FMOD_RESULT, char const*, int)'
play_stream.cpp:(.text+0x67): undefined reference to `FMOD::System::getVersion(unsigned int*)'
play_stream.cpp:(.text+0x81): undefined reference to `ERRCHECK_fn(FMOD_RESULT, char const*, int)'
play_stream.cpp:(.text+0xa2): undefined reference to `Common_Fatal(char const*, ...)'
play_stream.cpp:(.text+0xc0): undefined reference to `FMOD::System::init(int, unsigned int, void*)'
play_stream.cpp:(.text+0xda): undefined reference to `ERRCHECK_fn(FMOD_RESULT, char const*, int)'
play_stream.cpp:(.text+0xe6): undefined reference to `Common_MediaPath(char const*)'
You need to compile and link in common.cpp and common_platform.cpp
cool, at least that reduced the amount of errors. stupid me that i forgot the cpp´s. All “Common_…” and “ERRCHECK_…” are fixed now.
But what is still left are 16 undefined references to “FMOD::System”, “FMOD::Sound” and “FMOD::ChannelControl”. Any idea what i am doing wrong?
oh, and btw: I changed the name of “my” init back to “FMOD_Main()”, so it is back to the original “play_stream.cpp”
Hello, i have exactly the same issue with undefined references, is fmod 64 bits compatible with mingw in windows?
The C API of the supplied libraries are compatible with MinGW (C++ ABI not supported). The 64 bit dll can be linked directly. You will need to use the import library libfmod.a and libfmodstudio.a in order to link the 32 bit dlls.
https://www.fmod.com/resources/documentation-api?version=2.0&page=platforms-windows.html#libraries
