Hello, I’m trying to use the “Load Bank” node in UE4, and I seem to have run into a bug. I have a Master bank that’s 1 GB in size, and I’m using the Memory_GetStats function to monitor the memory usage.
When I use the Load Bank node on Begin Play, and set Load Sample Data to True, the max memory usage starts around 1 GB, and the current also starts high, but over the span of a few seconds it drops down to 13 MB. However in the Project Settings if I set “Load All Sample Data” to true, the current memory usage doesn’t drop and it stays around 1 GB for the remainder of the game. As further proof that the sample data might not be getting loaded properly through the Load Bank node, I can also notice the difference in audio latency - if I use the Load Bank node with Load Sample Data checked, my events have more of a delay compared to if I check “Load All Sample Data” in the Project Settings. I also found out that this only seems to be a problem with the Load Bank node, and if I use the Load Event Sample Data node, the samples do seem like they’re loaded. As a test I used the Load Bank node, and also used the Load Event Sample Data node for all the events in my Master Bank, and the current memory usage stayed near 1GB as expected.
Is this a known bug, or am I using this node wrong? I thought checking “Load Sample Data” in the Load Bank node would load the sample data for all of the events under that bank. Any help would be appreciated - thanks!
