Hello!
Recently I’ve noticed some problems with the region loop, I can clearly hear when the loop happens, the problem is when I put the sound “raw” and loop inside the FMOD, it works fine, if I make a crossfade, the loop didn’t work… And if I just mixdown the “raw” audio from the DAW (Studio One 5) without use crossfade, the loop also gets noisy… How can I manage with it?
