MixerStrip does not exist in the namespace
I’m having trouble accessing mixerstrips in Unity. I downloaded the latest Fmod Studio and Unity package from this site.
I have a separate strip for SFX and music and want the user to control their volume independently.
I have found some code here to do this, but I keep getting the following error:
Assets/_Scripts/menu/MenuUIManager.cs(27,29): error CS0234: The type or namespace name MixerStrip' does not exist in the namespaceFMOD.Studio’. Are you missing an assembly reference?
the line refered to is
FMOD.Studio.MixerStrip sfxBus;
the code I use is based on:
   public float volume = 1.0f;
   void Start()
      FMOD.GUID guid;
      FMOD.Studio.System system = FMOD_StudioSystem.instance.System;
      system.lookupID("bus:/SFX", out guid);
      system.getMixerStrip(guid, FMOD.Studio.LOADING_MODE.BEGIN_NOW, out sfxBus);
   void Update()
      sfxBus.setFaderLevel(volume);
Any ideas. What am I missing?
Thanks,
Jeroen
That API was changed in 1.5. There are some notes about it in the
documentation.
The new function is called getBus and takes a string which can either be a name or a guid representation. So your new code should look like this:
void Start()
   system.getBus("bus:/SFX", out sfxBus);
Thanks Geoff!
Should have read the docs more carefully.
