I tried this code so multiple sounds can be activated in the same scene but in different locations:
using System.Collections;
using UnityEngine;
public class AudioCollider : MonoBehaviour
public GameObject audioObject;
void Start()
audioObject = GameObject.FindGameObjectWithTag("Audio");
void OnTriggerEnter(Collider other)
if (other.CompareTag ("Player"))
audioObject.SetActive(true);
this.gameObject.SetActive(true);
This is my setup for the code:
It doesn’t work, why?
The first issue is you can’t find inactive game objects. As the Audio objects are all set to inactive at the start they will never get assigned. An alternative would be calling Play() on the Event Emitter instead. All event emitter functions can be found under FMOD Unity | Scripting API Reference.
Your new code would look like this:
public FMODUnity.StudioEventEmitter audioObject;
void Start()
audioObject.Play();
The added benefit is you have access to all the functions attached to the Event Emitter.
Now you will want to set all your Audio objects to Active in the scene and make sure their Play Event option is set to none:
You can leave Stop Event to destroy to make sure memory is cleaned up properly.
Are there any other errors being logged in the console window?
The console window is very useful too for debugging.
thankyou ! that helps a lot!!
it does give an error, i’ll try to find a way to fix it.
eitherway if anyone feels interested to find a solution: what the error is saying is that the Event Emitter is not a GameObject and it can not be assigned like such.
here’s my solution:
> using UnityEngine;
> public FMODUnity.StudioEventEmitter playingaudio;
> void Start()
> if (other.CompareTag("Player"))
> playingaudio.Play();
> void OnTriggerExit(Collider other)
> playingaudio.Stop();
Apologies, to solve the error
You could do something like
public FMODUnity.StudioEventEmitter audioPlaying;
void Start()
audioPlaying = audioObject.GetComponent<FMODUnity.StudioEmitter>();
It’s ok! The other thing already helped a lot but this helps even more.
