Hey guys,
I seem to be having trouble getting studio to reproduce surround channels in 5.1. I’m using a Sound Blaster Fatality sb x-fi sound card and using the Dolby Digital Live encoding to create a real-time 5.1 bit stream (TOS-Link out, image attached). Since I work on consoles primarily, this helps me emulate how they output.
[attachment=0]Dolby Digital Live.jpg[/attachment]
My issue is that currently (v1.1.8) I do not get any signal going to my surround channels when using your examples.fspro. Interestingly, LF, RF, C, and LFE all work perfectly. When I pan a mono sound to the rear, or when I listen to your 6ch examples = no LS, or RS.
I am in 5.1 mode in the preferences and again - hearing the other channels as expected.
When I pull in a SMPTE (L,R,C,LFE,LS,RS) 6 ch test file it works as expected in Fmod Designer (through DD Live encoder) whereas in Studio I do not get any surround signal.
I would expect that the same result would happen on the consoles… but I’m unable to test this.
Thanks for your help,
-Rich
