Hello
Why is Pcmreadcallback called only once, after calling FMODsystem.createSound, and not for every data from the microphone?
FMOD.CREATESOUNDEXINFO exinfo = new FMOD.CREATESOUNDEXINFO();
exinfo.cbsize = Marshal.SizeOf(exinfo);
exinfo.numchannels = 2; // nativeChannels;
exinfo.format = FMOD.SOUND_FORMAT.PCM16;
exinfo.defaultfrequency = 44100; // nativeRate;
exinfo.pcmreadcallback += Pcmreadcallback;
exinfo.length = (uint)(exinfo.defaultfrequency * sizeof(short) * exinfo.numchannels);
byte[] data = null;
res = FMODsystem.createSound(data, FMOD.MODE.LOOP_NORMAL | FMOD.MODE.OPENUSER,
ref exinfo, out sound);
if (res != RESULT.OK) return false;
FMODsystem.update();
res = FMODsystem.recordStart(id, sound, true);
res = FMODsystem.playSound(sound, null, false, out channel);
