Hello Guys,
I’m writing a Unity class to playback and capture audio data from a microphone.
Playback part works fine I can hear my voice in the headphones but I cannot access audio samples because pcmsetposcallback is never called during playback.
It is called only once inside createSound method.
I think i’m missing some setting , also tried several OR combinations for FMOD.MODE flag but with no luck.
Thanks in advance.
Walter
public class AudioInit : MonoBehaviour {
FMOD.System lowlevel = null;
FMOD.Sound snd = null;
// callbacks delegates
FMOD.SOUND_PCMREADCALLBACK pcmreadcallbackPtr = new FMOD.SOUND_PCMREADCALLBACK (pcmreadcallbackFunc);
FMOD.SOUND_PCMSETPOSCALLBACK pcmsetposcallbackPtr = new FMOD.SOUND_PCMSETPOSCALLBACK(pcmsetposcallbackFunc);
int driverId;
// Use this for initialization
void Start () {
int channels = 1;
int sampleRate = 8000;
float recordTime = 1.0f;
// get low level instance
FMOD_StudioSystem.instance.System.getLowLevelSystem(out lowlevel);
// fill sound info struct
FMOD.CREATESOUNDEXINFO soundInfo = new FMOD.CREATESOUNDEXINFO ();
soundInfo.cbsize = System.Runtime.InteropServices.Marshal.SizeOf (typeof(FMOD.CREATESOUNDEXINFO));
soundInfo.length = (uint)(sampleRate * channels * sizeof(byte) * recordTime);
soundInfo.numchannels = channels;
soundInfo.defaultfrequency = sampleRate;
soundInfo.format = FMOD.SOUND_FORMAT.PCM8;
soundInfo.pcmreadcallback = pcmreadcallbackPtr;
soundInfo.pcmsetposcallback = pcmsetposcallbackPtr;
soundInfo.dlsname = IntPtr.Zero;
// FMODE MODE flag
FMOD.MODE mode = FMOD.MODE.OPENUSER | FMOD.MODE.LOOP_NORMAL;
// create sound
FMOD.RESULT res = lowlevel.createSound((string)null, mode, ref soundInfo, out snd);
if (res != FMOD.RESULT.OK) {
Debug.Log ("ERROR snd " + res.ToString ());
return;
// get driver
res = lowlevel.getDriver (out driverId);
Debug.Log ("ERROR getDriver " + res.ToString ());
return;
// start record from microphone
res = lowlevel.recordStart (driverId, snd, true);
Debug.Log ("ERROR recordStart " + res.ToString ());
return;
uint pos = 0;
uint tries = 10;
// wait for a valid record position
while ( !(pos > 0) && (tries--) > 0 ) {
if ( lowlevel.getRecordPosition(driverId, out pos) == FMOD.RESULT.OK ){
System.Threading.Thread.Sleep(100);
} else { break; }
if ( !( pos > 0 )) {
Debug.Log ("ERROR invalid record position");
return;
// start playback
FMOD.Channel chn;
res = lowlevel.playSound (snd, new FMOD.ChannelGroup (IntPtr.Zero), false, out chn);
return;
// not used
static FMOD.RESULT pcmsetposcallbackFunc(IntPtr soundraw, int subsound, uint position, FMOD.TIMEUNIT postype)
return FMOD.RESULT.OK;
// only called once during lowlevel.createSound execution
static FMOD.RESULT pcmreadcallbackFunc (IntPtr sound, IntPtr data, uint len){
Debug.Log("pcmreadcallback sample size " + len.ToString());
void Update () {
