We have a multi-platform project and we noticed there is a big performance overhead related to calling setVolume, getPlaybackState, setParameterByID and set3DAttributes on EventInstances, from multiple threads. While this logic is present on other platforms, this issue seems exclusive to the PS5.
To give it a bit more context, we have 4 fiber jobs, each running on a separate thread, responsible with adjusting the volume on multiple EventInstances.
Looking at RAZOR CPU profiler measurements, we saw these jobs stall a lot due to multiple mutex waits called on setVolume (e.g, on the 4 threads, each one takes 20ms, while if we attempt to process audio on a single thread, it takes 1ms). We wanted to know if there are best practices when dealing with multiple setVolume calls.
Grouping these Instances into Groups and performing a single setVolume is not feasible as the instances’ volumes are rather independent. Additionally, we also checked if the command buffer was getting filled and while getBufferUsage accuses around 3/4 stalls for around 0.007s, increasing the command buffer memory does not yield any significant results.
For best practices, you could consider strategies to reduce the volume of API calls. Each time a command is written we aquire a lock around the command queue. If writing the command fails due to the queue being full, we increase the size of the command queue and try writing the command again- all the while holding the command queue crit.
Any other thread attempting to write to the command queue will be blocked while this is occurring, in particular most set and get calls, including the ones you’ve identified.
Expanding the command buffer memory may resolve this with a sufficiently large buffer size- but you would still get stalls from each of the set/get calls that independently aquire the command queue crit.
So if 3/4 of the stalls you are seeing are coming from expanding the command queue size, it sounds like you might have a high volume of API calls, and you may want to consider strategies to reduce the amount of calls occuring. Not sure if any of these apply to you, but as examples:
Skip identical API calls:
Something that doesn’t move doesn’t need set3DAttributes called on it every frame- by caching the last position you can check if the position has changed since the last game loop, and skip set3DAttributes if it hasn’t. The same applies to setParameterByID with the same parameter value every tick.
Throttle state changes:
Used in conjunction with the above- if the position or parameter is moving by a small amount and wouldn’t make much of an audible difference, don’t commit to a setVolume/setParameterByID/set3DAttributes until it crosses some threshold.
Add distance culling for API calls:
If the listener is outside the EventInstance’s max distance you might not need to call setVolume, getPlaybackState, or setParameterByID on it every frame.
As for why this is only occurring on PS5 I’m not sure. I am finding synchronization occurs more slowly on PS5 in general, but all in the realm of microseconds from my testing- nothing like the 20ms you are seeing.
Can you please upload this Razor CPU capture to your FMOD Profile so I can take a look?
Thanks for the upload- I see what you mean now, I read this as setVolume taking 20ms, but it looks like it’s the fibers that are each taking 20ms, each consisting of many individual calls to setVolume/set3DAttrributes etc.
The Studio Update thread isn’t running for the first 10ms of each update, so it’s unrelated to the size of the command queue, and everything to do with the threads fighting for the command queue crit.
Because all fibers are all trying to access the command queue at the same time, they can only get one API call in at a time before needing to rejoin the slow mutex wait queue (This appears to be a FIFO thread scheduling policy).
I think this problem could be solved by allowing a way for you to explicitly seize the command queue mutex so you can execute a batch of API commands. I’ll discuss this with the Dev team and see if there are any future improvements we could consider.
For now, I think if you allowed each fiber to execute multiple API calls before switching that might give you better performance- you mentioned single threaded command updates complete in 1ms so it sounds like you might already have a workaround for this issue. Please let me know if that’s not the case and we can discuss different ways to potentially mitigate this problem.
