Hi ,
In new Fmod version 2 there is no more way to double click on parameter value and than input the exact one you want. Only way to set parameter value in sandbox for example is to slide the value which is not instant behavior. That was the way it worked before so i guess you just forgot about it.
I am talking about this in case i didn’t explain it well
Thank you
