Pops/clicks audible as playhead reaches beginning of audio file?
Hey! First post here, I have essentially the same problem as in this reply to a post: Inconsistent fade envelopes - #11 by g.hadji
The problem: during a transition section to a Multi instrument, a varying pop/click is audible at the point the playhead touches the Destination region; the destination region plays at full volume for a few milliseconds, then is attentuated correctly according the fade-in. I mainly am using Multis to make randomised compositions and need to do this all the time, but I’m fairly new to FMOD - perhaps I am missing something obvious?
Is the only way to fix this by changing the ‘frame’ rate or update rate of FMOD, or was another fix made?
Thank you for your time :slight_smile:
The issue discussed in that thread is different to the issue you describe. (The original answer that Richard gave was incorrect, due to a miscommunication between Richard and one of our developers; the cause of the issue was unrelated to the update frequency of FMOD, and adjusting the frame rate was not an effective fix to the issue. The correct answer Richard later gave addressed an issue where extremely short fade curves were partly or entirely skipped, not to instruments briefly playing at full volume before the start of a fade-in curve.)
I’ve not been able to reproduce the behaviour you describe while testing here. Are you able to upload a project that exhibits the issue to your profile page on this website, so that we can see exactly what your’e doing when it occurs?
Hello again, please accept my apologies for not getting back to you promptly! Went on holiday and this issue completely slipped my mind after :frowning:
Here’s what’s happening:
Video: 2025-04-08 14-46-46.mp4 - Google Drive
FMOD Project: TEST 1.fspackage - Google Drive
I’m wondering whether this is a kind of order of operations issue? As in, the playhead must first select a file to play from the multi instrument, and then only afterwards applies any transition fades? And what we’re hearing is the delay between the two?
I’d love some assistance with this problem, and sorry again for getting back to you so late! Thank you :slight_smile:
Thanks for sending us that example! I’ve subsequently been able to reproduce the issue, and it definitely seems like a bug. Accordingly, I’ve added it to our bug tracker to be fixed in an upcoming version of FMOD Studio.
Unfortunately, I haven’t been able to find a simple workaround for this issue, other than avoiding destination instrument fade-in curves entirely.
