I am trying to get frequency spectrum data using FMOD_DSP_TYPE_FFT, and then getting a float parameter FMOD_DSP_FFT_DOMINANT_FREQ. However, the dominant frequency is always being returned as zero.
There are no errors while compiling my code.
I tried with
Relevant Snippets of code
Initialization function ()
FMOD::DSP *dsp;
float ChanPitch;
result = system->createDSPByType(FMOD_DSP_TYPE_FFT, &dsp);
result = channel->addDSP(FMOD_DSP_PARAMETER_DATA_TYPE_FFT, dsp);
result = dsp->setBypass(false);
//callled every frame
loop function ()
spec->getParameterFloat(FMOD_DSP_FFT_DOMINANT_FREQ, &ChanPitch, 0, 0);
**full code (using a modified version of the effects example**
int FMOD_Main()
FMOD::System *system = 0;
FMOD::Sound *sound = 0;
FMOD::Channel *channel = 0;
FMOD::ChannelGroup *mastergroup = 0;
FMOD::DSP *dsp ;
FMOD::DSP *dspflange = 0;
FMOD_RESULT result;
unsigned int version;
float dfft=0 ;
void *extradriverdata = 0;
Common_Init(&extradriverdata);
Create a System object and initialize
result = FMOD::System_Create(&system);
ERRCHECK(result);
result = system->getVersion(&version);
ERRCHECK(result);
if (version < FMOD_VERSION)
Common_Fatal("FMOD lib version %08x doesn't match header version %08x", version, FMOD_VERSION);
result = system->init(32, FMOD_INIT_NORMAL, extradriverdata);
ERRCHECK(result);
result = system->getMasterChannelGroup(&mastergroup);
ERRCHECK(result);
result = system->createSound(Common_MediaPath("drumloop.wav"), FMOD_DEFAULT, 0, &sound);
ERRCHECK(result);
result = system->playSound(sound, 0, false, &channel);
ERRCHECK(result);
Create some effects to play with
result = system->createDSPByType(FMOD_DSP_TYPE_FLANGE, &dspflange);
Add them to the master channel group. Each time an effect is added (to position 0) it pushes the others down the list.
result = mastergroup->addDSP(0, dsp);
result = mastergroup->addDSP(0, dspflange);
result = mastergroup->addDSP(FMOD_DSP_PARAMETER_DATA_TYPE_FFT, dsp);
By default, bypass all effects. This means let the original signal go through without processing.
It will sound 'dry' until effects are enabled by the user.
result = dspflange->setBypass(true);
Main loop
do
FMOD_DSP_PARAMETER_FFT *fft= nullptr;
dsp->getParameterData(FMOD_DSP_FFT_SPECTRUMDATA, (void **)fft, 0, 0, 0);
for (int channel = 0; channel < 1; channel++)
for (int bin = 0; 10; ++bin)
float freqVal = fft->spectrum[channel][bin];
Common_Update();
if (Common_BtnPress(BTN_MORE))
bool paused;
result = channel->getPaused(&paused);
paused = !paused;
result = channel->setPaused(paused);
dfft=dsp->getParameterFloat(FMOD_DSP_FFT_DOMINANT_FREQ, &dfft, 0, 0);
if (Common_BtnPress(BTN_ACTION3))
bool bypass;
result = dsp->getBypass(&bypass);
bypass = !bypass;
result = dsp->setBypass(bypass);
if (Common_BtnPress(BTN_ACTION4))
bool bypass;
result = dspflange->getBypass(&bypass);
bypass = !bypass;
result = dspflange->setBypass(bypass);
result = system->update();
bool paused = 0;
bool dspecho_bypass;
bool dspflange_bypass;
dsp ->getBypass(&dspecho_bypass);
dspflange ->getBypass(&dspflange_bypass);
if (channel)
if ((result != FMOD_OK) && (result != FMOD_ERR_INVALID_HANDLE) && (result != FMOD_ERR_CHANNEL_STOLEN))
Common_Draw("==================================================");
Common_Draw("Effects Example.");
Common_Draw("Copyright (c) Firelight Technologies 2004-2017.");
Common_Draw("");
Common_Draw("Press %s to pause/unpause sound", Common_BtnStr(BTN_MORE));
Common_Draw("Press %s to toggle dsplowpass effect", Common_BtnStr(BTN_ACTION1));
Common_Draw("Press %s to toggle dsphighpass effect", Common_BtnStr(BTN_ACTION2));
Common_Draw("Press %s to toggle dsp Spectrum e", Common_BtnStr(BTN_ACTION3));
Common_Draw("Press %s to toggle dspflange effect", Common_BtnStr(BTN_ACTION4));
Common_Draw("Press %s to quit", Common_BtnStr(BTN_QUIT));
Common_Draw("");
Common_Draw("%f",dfft);
Common_Draw("%s : spectrum[%c] flans[%c] echo[%c] flange[%c]",
paused ? "Paused " : "Playing",
dspecho_bypass ? ' ' : 'x',
dspflange_bypass ? ' ' : 'x');
Common_Sleep(50);
} while (!Common_BtnPress(BTN_QUIT));
Shut down
result = mastergroup->removeDSP(dsp);
result = mastergroup->removeDSP(dspflange);
result = dsp->release();
result = dspflange->release();
result = sound->release();
result = system->close();
result = system->release();
Common_Close();
return 0;
