Spectrum data to frequency Unity
Hey,
I would like to determine the frequencies by the spectrum. Unfortunately I always get wrong values ​​when I compare it with
fft.getParameterFloat((int)DSP_FFT.DOMINANT_FREQ, out dominantFreq);
I read this contribution to me.
https://qa.fmod.com/t/calculate-the-frequency-with-spectrum-data/14042/3
unfortunately I’m still doing something wrong and I can not get it
This is my Code
        float nyquistRate = (44100 / 2);
        float numEntries = (FftWindowSize / 2);
        float hzPerEntry = (nyquistRate / numEntries);
        float entrypower = 0;
        float biggest = 0;
        frequency = new float[(int)numEntries];
        for(int i = 0; i < numEntries; i++)
            entrypower = spectrumData[0][i] * hzPerEntry;
            if (entrypower > biggest)
                biggest = entrypower;
How are the values wrong?
By stepping through the code, are you see expected values in the other variables?
I want to calculate the frequency from spectrumData. i compare my value “biggest” with fft.getParameterFloat((int)DSP_FFT.DOMINANT_FREQ, out dominantFreq);
but the value are wrong. As example, the value in “dominantFreq” is 724.3906 and the value in “biggest” is 10.45431.
What im doing wrong :frowning:
pls help!! :open_mouth:
just picking one value out of a noisy spectrum is not a good way to find the dominant frequency.
FMOD finds the value by lookign at the most significant values not just 1 value.
To find the value here is the code
    float average = 0.0f;
    float power = 0.0f;
    for (int i = 0; i < nyquist-1; ++i)
        float hz = i * (rate * 0.5f) / (nyquist-1);
        if (spectrum[i] > 0.0001f) // aritrary cutoff to filter out noise
            average += spectrum[i] * hz;
            power += spectrum[i];
    if (power > 0.001f)
        *dominant = average / power;
    else
        *dominant = 0;
