I’m having issue getting programmable sound to work in Unity with FMOD. I tried to create the FMOD sound from audioclip but it alway failed. I have provided the full source code for my test below.
Source code:
FMOD.Sound CreateSoundFromAudioClip(AudioClip clip, string name)
float[] samples = new float[clip.samples * clip.channels];
clip.GetData(samples, 0);
FMOD.System lowlevel = FMODUnity.RuntimeManager.LowlevelSystem;
uint lenbytes = (uint)(clip.samples * clip.channels * sizeof(float));
FMOD.CREATESOUNDEXINFO soundinfo = new FMOD.CREATESOUNDEXINFO();
soundinfo.length = lenbytes;
soundinfo.format = FMOD.SOUND_FORMAT.PCMFLOAT;
soundinfo.defaultfrequency = clip.frequency;
soundinfo.numchannels = clip.channels;
FMOD.RESULT result;
FMOD.Sound sound;
result = lowlevel.createSound("", FMOD.MODE.OPENUSER, ref soundinfo, out sound);
IntPtr ptr1, ptr2;
uint len1, len2;
result = sound.@lock(0, lenbytes, out ptr1, out ptr2, out len1, out len2);
Marshal.Copy(samples, 0, ptr1, (int)(len1 / sizeof(float)));
if (len2 > 0)
Marshal.Copy(samples, (int)(len1 / sizeof(float)), ptr2, (int)(len2 / sizeof(float)));
result = sound.unlock(ptr1, ptr2, len1, len2);
result = sound.setMode(FMOD.MODE.LOOP_NORMAL);
result = lowlevel.playSound(sound, channelGroup, false, out channel);
return sound;
It’s return error: ArgumentNullException: Argument cannot be null.Parameter name: dest
