Project independent path for Studio API scripts osx
I got my script to work if I put it into the projectfolder of the FMOD project by creating a /Scripts subdirectory. Placing the exact same script in Users/XX/Application Support/FMOD Studio/Scripts folder does not work, the script does not show up in FMOD studios Scripts menu.
Should it be put somewhere else if I want it to be available indendent of a specific project?
Thank you for sharing the information!
If you want the script to be available for all FMOD projects, the correct global macOS path is:
~/Library/Preferences/FMOD Studio/Scripts
Please note that the Library folder might be hidden by default, you can access it by using Go to Folder and entering ~/Library
