Am I correct that in order for an FMOD event to make use of parameters it must be instantiated and played with someEvent.start()? In other words, there isn’t a way to have a one-shot that is affected by parameters, right?
Assuming yes, how should one play a simple, non-looping event and stop it immediately when it is over? Or do I even have to stop it in that case? The main case I’m thinking about is a simple and short sound effect (like footsteps) that will be used many times and needs to respond to some parameters. Presumably I would keep the same instance of the event alive for some period of time, and it would be triggered many times, and at some point it would be released. If I don’t stop this event between firings, will it hang onto additional system resources? Are there any other best practices around this that I should be aware of? Thanks.
