Reaper Integration to FMOD 2.0 - unable to find .eel file
I have just installed the new update for FMOD and was interested in integrating with Reaper, but after following the directions on the user manual I still can't find the .eel script in Reaper's Action list. I am using a Mac and would be interested to know if anyone has done this.
I tried on Mac and PC versions of Reaper. Both times I had to “Load” the file manually, it wasn’t showing up through a search .
so, at the bottom of the Actions window: Select: ReaScript Load … then browse for the file
The import then works well on Mac and PC
Thanks for the solution. Problem solved.
