Recommended/usual paths for audio occlusion ("walls block sound") in Unity?
I noticed the Unreal integration guide has a section on Occlusion: https://www.fmod.com/docs/2.02/unreal/user-guide.html#occlusion
The Unity guide does not have an equivalent.
I’ve seen some posts from years ago, and some other clever tutorials, but to bring things up-to-speed, even at a high level:
(1) What are the fundamental differences to understand between Unreal vs. Unity with FMOD for this feature?
(2) Is there a standard/go-to way to add audio occlusion (“walls block sound”) using Unity-FMOD?
Occlusion in Unity and Unreal are achieved in the same way: Define a specific parameter for your events that will be used to control events’ occlusion behavior, build occlusion behavior into all the events you want to be occlude-able by using that parameter to automate effect properties or trigger instruments, use ray casting within your game engine to calculate the values to which that parameter should be set, and the the parameter’s value accordingly.
Unreal differs from Unity only in that it provides a field for specifying the name of the parameter to be used for occlusion, as a convenience feature.
For information on how to perform ray casting within your engine of choice, see that engine’s documentation.
Thank you for the tidy summary, Joseph, and clarifying that difference.
