record and output to .wav file
I want to record sound and save to a .wav file. But when i use system->setOutput(FMOD_OUTPUTTYPE_WAVWRITER). getRecordNumDrivers return 0, so i cant record sound, Could anyone please tell me how to record sound and save to .wav file? What’s the problem in my code?
thanks,
xq
When you select an output mode you control which interface with sound devices you have. Unfortunately input (recording) and output are tied together. So if you choose wav writer output there is no interface for microphone recording.
We have a Windows example from FMOD 4 called ‘record to disk’ that shows how to do this. I’ll include the sample code here, it might need some minor tweaks for FMOD 5 compatibility.
Record to disk example
Copyright (c), Firelight Technologies Pty, Ltd 2004-2015.
This example shows how to do a streaming record to disk.
#include <windows.h>
#include <stdio.h>
#include <conio.h>
#include "../../api/inc/fmod.hpp"
#include "../../api/inc/fmod_errors.h"
void ERRCHECK(FMOD_RESULT result)
    if (result != FMOD_OK)
        printf("FMOD error! (%d) %s\n", result, FMOD_ErrorString(result));
        exit(-1);
#if defined(WIN32) || defined(__WATCOMC__) || defined(_WIN32) || defined(__WIN32__)
    #define __PACKED                         /* dummy */
#else
    #define __PACKED __attribute__((packed)) /* gcc packed */
#endif
    [DESCRIPTION]
    Writes out the contents of a record buffer to a file.
    [PARAMETERS]
    [RETURN_VALUE]
    void
    [REMARKS]
void WriteWavHeader(FILE *fp, FMOD::Sound *sound, int length)
    int             channels, bits;
    float           rate;
    if (!sound)
        return;
    fseek(fp, 0, SEEK_SET);
    sound->getFormat  (0, 0, &channels, &bits);
    sound->getDefaults(&rate, 0, 0, 0);
        #if defined(WIN32) || defined(_WIN64) || defined(__WATCOMC__) || defined(_WIN32) || defined(__WIN32__)
        #pragma pack(1)
        #endif
            WAV Structures
        typedef struct
            signed char id[4];
            int 		size;
        } RiffChunk;
        struct
            RiffChunk       chunk           __PACKED;
            unsigned short	wFormatTag      __PACKED;    /* format type  */
            unsigned short	nChannels       __PACKED;    /* number of channels (i.e. mono, stereo...)  */
            unsigned int	nSamplesPerSec  __PACKED;    /* sample rate  */
            unsigned int	nAvgBytesPerSec __PACKED;    /* for buffer estimation  */
            unsigned short	nBlockAlign     __PACKED;    /* block size of data  */
            unsigned short	wBitsPerSample  __PACKED;    /* number of bits per sample of mono data */
        } FmtChunk  = { {{'f','m','t',' '}, sizeof(FmtChunk) - sizeof(RiffChunk) }, 1, channels, (int)rate, (int)rate * channels * bits / 8, 1 * channels * bits / 8, bits } __PACKED;
        struct
            RiffChunk   chunk;
        } DataChunk = { {{'d','a','t','a'}, length } };
        struct
            RiffChunk   chunk;
            signed char rifftype[4];
        } WavHeader = { {{'R','I','F','F'}, sizeof(FmtChunk) + sizeof(RiffChunk) + length }, {'W','A','V','E'} };
        #pragma pack()
        #endif
            Write out the WAV header.
        fwrite(&WavHeader, sizeof(WavHeader), 1, fp);
        fwrite(&FmtChunk, sizeof(FmtChunk), 1, fp);
        fwrite(&DataChunk, sizeof(DataChunk), 1, fp);
int main(int argc, char *argv[])
    FMOD::System          *system  = 0;
    FMOD::Sound           *sound   = 0;
    FMOD_RESULT            result;
    FMOD_CREATESOUNDEXINFO exinfo;
    int                    key, recorddriver, numdrivers, count;
    unsigned int           version;
    FILE                  *fp;
    unsigned int           datalength = 0, soundlength;
        Create a System object and initialize.
    result = FMOD::System_Create(&system);
    ERRCHECK(result);
    result = system->getVersion(&version);
    ERRCHECK(result);
    if (version < FMOD_VERSION)
        printf("Error!  You are using an old version of FMOD %08x.  This program requires %08x\n", version, FMOD_VERSION);
        return 0;
        System initialization
    printf("---------------------------------------------------------\n");
    printf("Select OUTPUT type\n");
    printf("1 :  DirectSound\n");
    printf("2 :  Windows Multimedia WaveOut\n");
    printf("3 :  ASIO\n");
    printf("Press a corresponding number or ESC to quit\n");
    do
        key = _getch();
    } while (key != 27 && key < '1' && key > '5');
    switch (key)
        case '1' :  result = system->setOutput(FMOD_OUTPUTTYPE_DSOUND);
                    break;
        case '2' :  result = system->setOutput(FMOD_OUTPUTTYPE_WINMM);
                    break;
        case '3' :  result = system->setOutput(FMOD_OUTPUTTYPE_ASIO);
                    break;
        default  :  return 1;
    ERRCHECK(result);
        Enumerate record devices
    result = system->getRecordNumDrivers(&numdrivers);
    ERRCHECK(result);
    printf("Choose a RECORD driver\n");
    for (count=0; count < numdrivers; count++)
        char name[256];
        result = system->getRecordDriverInfo(count, name, 256, 0);
        ERRCHECK(result);
        printf("%d : %s\n", count + 1, name);
    recorddriver = 0;
    do
        key = _getch();
        if (key == 27)
            return 0;
        recorddriver = key - '1';
    } while (recorddriver < 0 || recorddriver >= numdrivers);
    printf("\n");
    result = system->init(32, FMOD_INIT_NORMAL, 0);
    ERRCHECK(result);
    memset(&exinfo, 0, sizeof(FMOD_CREATESOUNDEXINFO));
    exinfo.cbsize           = sizeof(FMOD_CREATESOUNDEXINFO);
    exinfo.numchannels      = 1;
    exinfo.format           = FMOD_SOUND_FORMAT_PCM16;
    exinfo.defaultfrequency = 44100;
    exinfo.length           = exinfo.defaultfrequency * sizeof(short) * exinfo.numchannels * 2;
    result = system->createSound(0, FMOD_2D | FMOD_SOFTWARE | FMOD_OPENUSER, &exinfo, &sound);
    ERRCHECK(result);
    printf("========================================================================\n");
    printf("Record to disk example.  Copyright (c) Firelight Technologies 2004-2015.\n");
    printf("\n");
    printf("Press a key to start recording to record.wav\n");
    printf("\n");
    _getch();
    result = system->recordStart(recorddriver, sound, true);
    ERRCHECK(result);
    printf("Press 'Esc' to quit\n");
    printf("\n");
    fp = fopen("record.wav", "wb");
    if (!fp)
        printf("ERROR : could not open record.wav for writing.\n");
        return 1;
        Write out the wav header.  As we don't know the length yet it will be 0.
    WriteWavHeader(fp, sound, datalength);
    result = sound->getLength(&soundlength, FMOD_TIMEUNIT_PCM);
    ERRCHECK(result);
        Main loop.
    do
        static unsigned int lastrecordpos = 0;
        unsigned int recordpos = 0;
        if (_kbhit())
            key = _getch();
        system->getRecordPosition(recorddriver, &recordpos);
        ERRCHECK(result);
        if (recordpos != lastrecordpos)
            void *ptr1, *ptr2;
            int blocklength;
            unsigned int len1, len2;
            blocklength = (int)recordpos - (int)lastrecordpos;
            if (blocklength < 0)
                blocklength += soundlength;
                Lock the sound to get access to the raw data.
            sound->lock(lastrecordpos * exinfo.numchannels * 2, blocklength * exinfo.numchannels * 2, &ptr1, &ptr2, &len1, &len2);   /* * exinfo.numchannels * 2 = stereo 16bit.  1 sample = 4 bytes. */
                Write it to disk.
            if (ptr1 && len1)
                datalength += fwrite(ptr1, 1, len1, fp);
            if (ptr2 && len2)
                datalength += fwrite(ptr2, 1, len2, fp);
                Unlock the sound to allow FMOD to use it again.
            sound->unlock(ptr1, ptr2, len1, len2);
        lastrecordpos = recordpos;
        printf("%-23s. Record buffer pos = %6d : Record time = %02d:%02d\r", (timeGetTime() / 500) & 1 ? "Recording to record.wav" : "", recordpos, datalength / exinfo.defaultfrequency / exinfo.numchannels / 2 / 60, (datalength / exinfo.defaultfrequency / exinfo.numchannels / 2) % 60);
        system->update();
        Sleep(10);
    } while (key != 27);
    printf("\n");
        Write back the wav header now that we know its length.
    fclose(fp);
        Shut down
    result = sound->release();
    ERRCHECK(result);
    result = system->release();
    ERRCHECK(result);
    return 0;
Very good. you save my life! Thank you very much.
