Reference Monobehaviours from PCMReadCallback?
I have created a custom audio generator and want to play it through FMOD in Unity on Windows. However whenever I access a Monobehaviour from PCMReadCallback Unity freezes. So far I’ve worked out that the callback is run on a different thread (I’m assuming a thread spawned by FMOD for audio processing) and I’m guessing due to Unity’s lack of multithreading support this is causing issues. How can I get around this and get data from another object into the FMOD callback from an external generator?
Here’s an example of code snippet that I’d like to work.
Although I’m not sure it will fix all your issues I’ve spotted a common flaw in your code.
exinfo.pcmreadcallback = pcmreadcallback;
is short hand for
var cb = new SOUND_PCMREADCALLBACK(pcmreadcallback);
exinfo.pcmreadcallback = cb;
and now you’ve passed a reference to FMOD of a managed object that is only in the local scope and will garbage collected some time after your FMODStreamPlayer.CreateStream method has finished.
You need initialise a SOUND_PCMREADCALLBACK (and also a SOUND_PCMSETPOSCALLBACK) class member variable that will stay around while FMOD is still issuing the callback.
This seemed to be causing the issue. Its working now and I can reference other components from the callback. There is still an issue with Unity sometimes crashing when I stop the editor however.
Be very conservative in what managed objects you access. Try not to allocate any managed objects.
