Requesting Option to set up the Channel Speaker Layout from an Event (Any Event) instead of throughout the Project
ok, this may sound dumb and entirely unnecessary, but i promise i’ll provide a possible use case for this rather long thread title, so please bear with me.
i have ~10 existing asset files, (e.g. 10 files), all sharing the same length (e.g. 2-3 min). when i create an event, i make new audio tracks from an event that will accommodate these files. however, these files may have varying channel counts between them.
file 1 is stereo, file 2 is mono, file 3 is stereo, file 4 is left+right+center, file 5 is mono, you get the idea.
the one thing i would like to do here is to “implement” a kind of channel speaker layout from each track in any given event however i see fit.
track 1 represents file 2. i want to assign “front-left+front-right” channel speaker tags to this track even if it’s all unnecessary.
track 4 represents file 4. assign “front-left+front-right+front-center” channel speaker tags to this track.
track 2 represents file 2. assign “LFE” channel speaker tag to this track. and so on and so forth.
channel speaker tags should come from a combination of various tags, all representing a given channel speaker. like “front left”, “rear left”, “LFE”, etc. perhaps some existing tags for the overhead and floor channels, or maybe even entire tags consisting of entire channel speaker layouts even (7.1.5.4, 9.1.6, etc.), all combined from existing channel speaker tags.
as for “throughout the Project”, i’m referring to setting one of the three options of the exact channel speaker layouts available on your project.
let me know what y’all think.
If I understand correctly, you want to be able to specify exactly which speaker channels your tracks’ audio channels represent, so that you can use different audio tracks for different speaker tracks and have it all work when those tracks are mixed together.
Have you tried using the existing channel mix effect for this? If I’ve understood what you’re trying to do, it seems like the right tool for the job.
If the channel mix effect doesn’t work for you, could you describe how it fell short of your requirements, so that we better understand your needs?
i’ll try the channel mix effect.
