Hi, I want to make a script for FMOD Studio(2.0), get all the programmer instrument (quantities: 50+)position and name, So I can make them to trigger some timline events in game, is it possible?
Thanks a lot.
You can do this within FMOD Studio with a script such as the following
events.forEach(function(event) {
programmerInstruments = [];
instruments = event.timeline.modules;
instruments.forEach(function(inst) {
if (inst.entity === "ProgrammerSound") {
programmerInstruments.push(inst);
programmerInstruments.forEach(function(programmerInst){
console.log(event.name + "\r\n " + programmerInst.name + ": " + programmerInst.start);
If this is something you are performing at runtime, you can just call Studio::EventInstance::getTimelinePosition() at the time you are setting the programmer instruments sound.
Thx, it works!
So, how Can I know when does the instrument stop?
You will need to add (programmerInst.start + programmerInst.length) to the last forEach console output.
Thanks a lot!
Where can i get these function info?
https://www.fmod.com/resources/documentation-studio?version=2.1&page=scripting-api-reference-project.html
I didn’t find these Programmerinstrument function in the document.
The programmerInst is a variable that’s instantiated when you call the forEach() function. programmerInst is the current programmer instrument whilst looping through the programmerInstruments array.
This is more of a Javascript/coding issue than an FMOD Studio scripting API issue.
