For various reasons, i’m investigating this: Is it possible to send parameters from fmod to unreal? Like distance and whatever else I like?
I know that these things are generated in fmod from the beginning and sent to fmod. But just ignore that for now
Can it be done?
Thanks
It is possible to set either local and global parameters via Blueprints:
Or via code:
Sorry, typo in my heading and text (had words reversed).
I want to send parameters FROM fmod to unreal. Not the otherway around
Thanks
No worries!
It is possible to read parameters on events with the get functions:
If that is the behavior you are after. If not, could I get an example of a use case that you are looking for?
I think first of all they are curious if we can read distance from fmod.
But will investigate if they need to know more.
Great! thanks a lot
