it seems when searching for event-references of an existing snapshot, ALL events will be shown as an result, instead of the events that are linked to the snapshot.
to reproduce:
make new project
create two events A and B
create new snapshot SNP
make snapshot instrument with SNP in event A
search for referenced events of SNP (right click)
both events A and B will be displayed
this is ofc quite a disappointment, since for big projects it’s nearly impossible to look through each and every event for an possible Snapshot-Reference manually.
This is definitely a bug. Finding references of snapshots in events should only return events that use that snapshot as a snapshot instrument. Instead it seems to be displaying everything regardless if it uses the snapshot or not. Thank you for bringing this to our attention.
That`s strange. This only happens with existing return buses in my project which I use as aux reverb channels. They have convolution reverbs inserted. When I click on this, it just lists all the events in the project.
But the funny thing is that I can not reproduce this with any new return buses. It just happens with the existing ones in the project. I get the same result for every one of them.
Version is 2.01.09 64-bit and validate project came up with no errors.
Hello, I tried to do as you said but then it only shows all the folders but empty. It’s like the return bus have a reference to the folders themselves.
#references:{921f79b5-0e5a-46a2-88ae-035efa5d39fc} NOT {2a276e49-2749-4212-a39a-72385b29ff07}
this is generated in the search field
That’s very odd. Are you able to package the project without the assets (File > Package Project) and send it over for me to look at? There might be a way to “refresh” the buses that are being affected by this issue. You can DM me a link for privacy.
