Getting an issue with tthe server - i believe it something to do with the opening cutscene and crashing the server.
| [11:44:34.249][Warning] | Parent of RectTransform is being set with parent property. Consider using the SetParent method instead, with the worldPositionStays argument set to false. This will retain local orientation and scale rather than world orientation and scale, which can prevent common UI scaling issues. |
| [11:44:34.252][Log] | SetInjuredState None |
| [11:44:34.326][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
| [11:44:34.327][Log] | Triggered Full cycle - with jump distance 1424.906 |
| [11:44:34.327][Log] | Fps Limiter set to -1 |
| [11:44:34.328][Log] | NavCuts::ForceUpdate Enabled=584 Disabled=580 (frame=1186). |
| [11:44:34.334][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
| [11:44:34.405][Log] | Fps Limiter set to 5 |
| [11:44:34.516][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
| [11:44:34.716][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
(repeats error thousands of times)
| [11:44:42.922][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
| [11:44:43.122][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
| [11:44:43.127][Log] | TriggerOpeningCutscene |
| [11:44:43.322][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
| [11:44:43.522][Error] | [FMOD] Error (ERR_INVALID_HANDLE): An invalid object handle was used. |
Any help is appreciated, thanks.
