I have a simple set up to test fmod and try it for the first time, i create the system, then load some sounds and then trying to play them while updating every frame.
im checking everything and everything is ok.
https://i.imgur.com/fDNEO2o.png
https://i.imgur.com/BxoAAux.png
i run fmodstudio update every frame loop.
Thank you for the images, would it be possible to get the full script either uploaded to your profile or DM’d to me? Please note that you will have to register a project with us before you can upload files.
Hi, I solved the problem, i wasn’t loading the main bank. Thanks for the reply.
