Hello, I have several pieces of BGM and I want to switch from one to another. How should I do that?
I have tried change the eventinstance of emitter but it didn’t work.
Thanks.
Thanks.
How are you playing the first BGM event? Could I get a code snippet of how you are trying to change events?
Fmod version is 2.02.11.
I set up event in the inspector and control it in Start method:
private void Start()
musicEmitter.Play();
isPlaying = true;
Here’s my ChangeMusic method:
public void ChangeMusic(string eventName)
musicEmitter.Stop();
musicEmitter.Event = eventName;
Emitter.Event has been deprecated and won’t change the event the emitter will play.
I would recommend making a public list of emitters:
public List<FMODUnity.StudioEventEmitter> emitters = new List<FMODUnity.StudioEventEmitter>();
You can then iterate through to start and stop:
emitters[0].Stop();
emitters[1].Play();
Let me know if this works for you, there are some other options too.
