hi all, congratulations for fmod
, i am a beginner entering the world of fmod. I am programming a drum machine, I wanted to know how I can change event in runtime? I use version 2.02.05
i tried to do
public class playb : MonoBehaviour
{ private FMOD.Studio.EventInstance instance;
public string[] sample;
int ind;
void selectSAMPLE()
{instance = FMODUnity.RuntimeManager.CreateInstance(sample[ind]);}
void PLAY()
{instance.start();
instance.release();
the goal is to change samples while it is in runtime …
I created 1 event for each sample and I would like … is this correct?
but I don’t know why the code doesn’t work
That should be enough to change the event at runtime, though I can see a couple of reasons why this script alone wouldn’t result in any audio playing back. To start with, are you calling these methods anywhere? For example, a fixed update loop that calls these functions would be a good start for a drum machine
int timeCounter = 0;
private void FixedUpdate() // Called 50 times per second
if(timeCounter++ == 0)
selectSAMPLE();
PLAY();
ind = (ind + 1) % sample.Length;
timeCounter = timeCounter % 10;
Also, you will need to make sure that elements in your sample array are the correct string paths, for example “event:/Music/Kick”, “event:/Music/Snare” etc. You can get these by right clicking on the event in FMOD Studio and selecting “Copy Path”.
If you haven’t already, I would recommend following with the Unity Integration Tutorial to get you started with Unity FMOD scripting if you are new to FMOD / Unity / Scripting in general.
