Sync game events to music beats?
If you set a tempo marker on the timeline in Studio then markers are automatically quantized to the beat (hold ctrl to dragging a marker to disable quantization).
If you want to get every beat, simply use the beat callback.
public class MarkerDemo : MonoBehaviour
    FMOD.Studio.EventInstance instance;
    FMOD.Studio.EVENT_CALLBACK cb;
    void Start()
        instance = FMOD_StudioSystem.instance.GetEvent("event:/Music/Complex/Situation_Oriental");
        cb = new FMOD.Studio.EVENT_CALLBACK(StudioEventCallback);
        instance.setCallback(cb, FMOD.Studio.EVENT_CALLBACK_TYPE.TIMELINE_MARKER | FMOD.Studio.EVENT_CALLBACK_TYPE.TIMELINE_BEAT);
        instance.start();
    public FMOD.RESULT StudioEventCallback(FMOD.Studio.EVENT_CALLBACK_TYPE type, IntPtr eventInstance, IntPtr parameters)
        if (type == FMOD.Studio.EVENT_CALLBACK_TYPE.TIMELINE_MARKER)
            FMOD.Studio.TIMELINE_MARKER_PROPERTIES marker = (FMOD.Studio.TIMELINE_MARKER_PROPERTIES)Marshal.PtrToStructure(parameters, typeof(FMOD.Studio.TIMELINE_MARKER_PROPERTIES));
            IntPtr namePtr = marker.name;
            int nameLen = 0;
            while (Marshal.ReadByte(namePtr, nameLen) != 0) ++nameLen;
            byte[] buffer = new byte[nameLen];
            Marshal.Copy(namePtr, buffer, 0, buffer.Length);
            string name = Encoding.UTF8.GetString(buffer, 0, nameLen);
            if (name == "HIGH")
                UnityEngine.Debug.Log("Reached high intensity marker");
        if (type == FMOD.Studio.EVENT_CALLBACK_TYPE.TIMELINE_BEAT)
            FMOD.Studio.TIMELINE_BEAT_PROPERTIES beat = (FMOD.Studio.TIMELINE_BEAT_PROPERTIES)Marshal.PtrToStructure(parameters, typeof(FMOD.Studio.TIMELINE_BEAT_PROPERTIES));
        return FMOD.RESULT.OK;
