The cost of the bank Encryption
Hi Forums, We try to use bank encryption to improve the security of bank. we added a key when we built the bank files and used the key to load bank file. It worked well.
We want to know what kind of encryption algorithm it is and is there any substitute that can reduce the overhead of encryption.
It will be great if there is some data about the performance of FMOD Encryption.
Thanks.
There is no substitute encryption algorithm. If you’re having specific performance issues that you think are related to encryption please let us know what they are.
Thank you Andrew, I will test the performance first.
In addition, could you please introduce the encryption algorithm of FMOD, or do you have relevant information?
Thanks, Andrew!
It’s proprietary.
Ok, anyway, Thank you!~
