打开工程程序未响应,后台检测到内存增加
Uploading: 3.png…
问题发生的时机在于我打开工程之后,大约五秒中后,程序就挂起了。尝试过多个版本,无法解决这个问题。
  • 2023-12-18 10:39:38 Resyncing (build: 692, delete: 0, mute: 0)
  • 2023-12-18 10:39:38 [Resync Auditioning Queue 0x00000241287e8cd0]: Time taken is 119.07ms
  • 2023-12-18 10:39:38 [Initialize Sound System 0x00000241287e8cd0]: Time taken is 159.48ms
  • 2023-12-18 10:39:38 [Resync Auditioning Queue 0x00000241287e8cd0]: Time taken is 178.81ms
  • 2023-12-18 10:39:38 [Resync auditioning D:\client\FMOD\GF_FMOD.fspro 0x00000241287e76f0]: Time taken is 178.85ms
  • 2023-12-18 10:39:38 [Opening D:\client\FMOD\GF_FMOD.fspro 0x00000241287e76f0]: Time taken is 962.44ms
  • 2023-12-18 10:39:38 [Total Load D:\client\FMOD\GF_FMOD.fspro 0x00000241287e76f0]: Time taken is 1038.56ms
    2023-12-18 10:39:38 Macro: Project recovery
  • 2023-12-18 10:39:38 [Scripting]ScriptServer started on 0.0.0.0 (3663)
    ! 2023-12-18 10:39:38 QPaintDevice: Cannot destroy paint device that is being painted [#14 times]
    2023-12-18 10:39:38 Event activated: [None]
建议你发英文帖,官方工程师应该看不懂中文。同样你给的信息我感觉很难推断,也不知道你机器配置,影响因素太多了,你后台这一堆运行,CPU和内存经不起折腾,看着占用不高未必跑得动,我工作只开Unity、Fmod和Edge,VS等随用随开,啥事儿没有。
哪怕重启只开FMOD也会无响应,i7 10700,GTX1660S。事实这个工程之前是正常使用的,会发生这个问题的也只出现在这个工程,一个新建的工程FMOD是正常的。不过使用版本管理工具的同事们,并没有出现我这个问题
What version of FMOD are you using? Would it be possible to get a copy of your project uploaded to your profile? Please note you will have to register a project with us before you can upload files.
I found that this problem only existed on my computer. If I click the audio after adding audio to a new project, the editor will still get stuck. I guess it is caused by something missing in my running environment.
It will always be so version 20123 and 20219
Could I get you to run DxDiag: Open and run DxDiag.exe - Microsoft Support. This will provide detailed information about your computer and may help diagnose the issue.
Could I also get the full reproduction steps to reproduce the issue and the exact FMOD Studio version you are using?
I’m using version 2.01.07
I can’t upload the log text,Because I’m a new user
I put the log on the website: ------------------System Information------------------ Time of this r - Pastebin.com
Thank you for the information. Unfortunately, we no longer support FMOD 2.01. Would it be possible to update to 2.02 and see if the issue continues?
