Hi there, I’ve run into this issue where the transition timeline is cutting off the transient of the destination. It must be fading it in somehow. I’ve double checked the positions of the clip start, destination and everything, also had Aaron and Connor from FMOD look it over.
FMOD Version 2.02.26
It happens regardless of where you put the destination; inside or outside the transition timeline. It plays regularly when positioning the playhead before the clip, without using a transition.
A fix was just to cut up the track and put the transient in the transition timeline.
I’m glad to hear you were able to find a solution to your problem.
It’s impossible to say why it was happening without looking at your project, but my first guess is that you may have set your transition region to an offset mode other than “none.” Transition offset modes are a way of making the exact destination of a transition vary depending on the position of the timeline playback position when it entered the transition, and so can easily result in the timeline playback position arriving at a point on the timeline other than the exact start of an asynchronous instrument, and thus in not playing its beginning.
If it’s not that, are you able to upload a version of your project containing the event in question, so that we can examine it in detail?
Thanks Joseph,
I did have them set on an offset (I didn’t notice if the issue was prevalent then) but had switched back to ‘None’ by the time the issue was there.
Here’s the attached project: Dropbox
Cheers!
I wasn’t able to reproduce the issue using the project you uploaded for us. That may be because I’ve misunderstood the issue. What should I do to reproduce it?
Thanks for uploading a version of your project that exhibits the issue. Unfortunately, I’m still not sure what problem I should be listening for; as far as I can tell, all triggered instruments play from their beginnings, as expected.
Again, it’s possible that I have simply misunderstood what I’m supposed to be listening for. Could you describe an example of how the issue might be reproduced?
Thanks Joseph,
It is quite subtle, but the kick drum has a fairly poppy transient being cut off at the transition. Listening to it on my computer you can hear a very short (20ms) fade that does ruin the transient of the first kick.
I can do some more testing
Hi @joseph - I’d love to reopen this thread as i have been encountering the same issue being described.
I’ve uploaded a redacted version of the event i’m working on. As it transitions from the trans region into the following loop there’s a clear fade in the volume, despite the Destination not utilising a fade.
This bug doesn’t always happen in every transition in every event but seems random. The fade in happens regardless of the length of the transition timeline.
Am i missing anything as to why this is happening?
Thanks for sending in a project! Thanks to that, I can see exactly why this is happening.
The instruments that start playing during the transition timeline all have fade-in curves. This is important because under-the-hood, fade curves work just like volume automation. Think of the fade curve that appears on the instrument trigger region as the visible section of an automation curve that extends the full length of the timeline or parameter: There’s also an invisible section to the left (that’s just a flat line at -oo dB), and another invisible section to the right (that’s also a flat line, this time at 0 dB). Those invisible flat lines aren’t particularly interesting most of the time (“constant full volume” and “constant silence” are hard to get excited about) which is why we don’t display them, but they are there.
This is important because of the way transition timelines handle automation curves. When an automation curve is set to one value at the source of a transition timeline and a different value at the destination of the transition timeline, and there are no automation points inside the transition timeline itself, the transition timeline will smoothly ramp the property value from its value at the source to its value at the destination.
In your case, the left invisible section of the fade-in curve’s automation means that the volume of the instruments is silent at the source of the transition timeline, and the right invisible section of the fade-in curve’s automation means that their volume is full at the destination of the transition timeline - and so the transition timeline automatically ramps those instruments up from silence to full volume.
If you want to avoid this behavior, all you need to do is replace the fade-in curve with a volume automation curve. This will allow you to create a curve that fades in the volume as you want, while also allowing you to set the volume to 0 dB at the source of the transition timeline so as to avoid the undesirable ramping.
@joseph So i’m still getting this issue in this event and not sure why. I’ve uploaded a new fspackage title ‘transition timeline fade bug 02’. You just have to switch the parameter to ‘combat’ in order t
I’ve removed ALL automation and any fades that were on the instruments itself, and it seems that there’s still this fade in. Not sure what im missing as in a completely new project i tested your explanation out and it worked as you described.
