Transition timeline to conditional transition marker
I have parts that conditionally transition to other parts when they reach the end; sometimes it’s a random between a couple different other parts, sometimes it’s depending on parameters…etc.
The issues is that my parts have baked reverb tails, and so when I add a transition timeline to have the baked reverb tail play simulaneously with the new part, it doesn’t work.
From looking at other issues, I assume it’s because when in a transition timeline, you can’t transition to something else. What would be the workaround then?
I’ve reproduced the issue in the screenshot (the original event had dozens of parts and parameters).
One of the workaround I imagined is to copy and paste the transition To markers at the end of each track instead of having a single clean point of entry like in my first screenshot (see screenshot below). While it works, it quickly becomes unmanageable with dozens 20-30 parts and their conditions.
What can I do in that situation? Thanks a lot in advance!
If I understand what you’re trying to do correctly, there are a few different ways to achieve what you want. The simplest is to remove all transition timelines from the event, and convert your instruments into asynchronous instruments by selecting each of them and clicking the “Async” button in its deck. This will allow them to continue playing even when untriggered, ensuring that their tails overlap with the starts of new instruments that begin playing.
Does that work for you?
