Transition Timeline (UX Suggestion)
Hi guys!
I encountered an issue prior to a milestone that drove me crazy: I had a music that was “dropping” (audio stopping with sometimes some layer playing the release or not) without any particular reason.
I tried to find the origin of the problem in deeper reasons than it was sadly, and couldn’t figure it out.
When I found the origin I was kinda mad at myself: it was an unwanted transition timeline, which was probably created by mistake over several dozens of measures.
I’m gonna take an extreme example, but… when you have setups like this :
… pin pointing a potential issue starts to be problematic.
So the idea would be to improve the transitions implementation like this:
  • When double clicking on a transition, if the transition timeline does not exists beforehand, open a prompt “would you like to create a transition timeline yes/no” ( enter=yes, esc=no + mouse)
  • When double clicking on a transition, if the transition timeline exists, open or close it (as usual)
  • When right clicking > Add transition timeline, keep current behavior to allow quick creations fast and easily
  • Finding a marker / color to replace the tiny dot, which is somewhat visible but when you are deep down in the rabbit hole in a project, sometimes it’s not obvious enough.
Cheers!
Olivier
A confirmation dialog when creating a new transition timeline by double-clicking, and a harder-to-overlook indication that a transition timeline is present? I can see how those would be useful. I’ll add your suggestions to our feature and improvement tracker.
Thank you @joseph !
I concur. My students often double click transitions or loops by accident and don’t realise what they have just done, then complain that there is a long dropout of silence that they can’t explain.
Thanks for the feedback. I’ve added you to the list of people who’ve requested these features.
