Trouble Loading Banks on Android Build 2.02.07
I’ve been struggling lately with loading banks on an Android build for Oculus Quest 2. Any help is appreciated! Version 2.02.07 and Unity 2021.3.3f1
The error is pasted below. I’ve tried a number of things from upgrading 2.02.04 to 2.02.07, double checking my oculus spatializer installation, deleting cache and fmodstudiocache.asset, etc.
The only clue I’ve found is that when running a Debug.LogError() in CopyToStreamingAssets() on the bankFilePaths, I get an odd backslash in the paths. Here is one bank for example. All follow the same pattern.
Assets/StreamingAssets\SFX.bank
This is was happening on both fmod versions, but I was not able to dig up if this was actually the cause of my issue.
I’ve tried single platform build, multi-platfrom builds, loading all banks, and loading specified banks. This project is not using “Split Application Binrary”
2022/08/18 00:13:30.244 6442 6542 Error Unity [FMOD] AndroidAssetFile::reallyOpen : Could not open 'Master.strings.bank' from the asset manager.
2022/08/18 00:13:30.244 6442 6542 Error Unity FMODUnity.RuntimeManager:DEBUG_CALLBACK(DEBUG_FLAGS, IntPtr, Int32, IntPtr, IntPtr)
2022/08/18 00:13:30.245 6442 6542 Error Unity [FMOD] RuntimeBankModel::openFile : Failed to open file 'file:///android_asset/Master.strings.bank'
2022/08/18 00:13:30.245 6442 6542 Error Unity FMODUnity.RuntimeManager:DEBUG_CALLBACK(DEBUG_FLAGS, IntPtr, Int32, IntPtr, IntPtr)
2022/08/18 00:13:30.301 6442 6464 Error Unity BankLoadException: [FMOD] Could not load bank 'file:///android_asset/Master.strings.bank' : ERR_FILE_NOTFOUND : File not found.
2022/08/18 00:13:30.301 6442 6464 Error Unity   at FMODUnity.RuntimeManager.loadedBankRegister (FMODUnity.RuntimeManager+LoadedBank loadedBank, System.String bankPath, System.String bankName, System.Boolean loadSamples, FMOD.RESULT loadResult) [0x00000] in <00000000000000000000000000000000>:0
2022/08/18 00:13:30.301 6442 6464 Error Unity   at FMODUnity.RuntimeManager.LoadBank (System.String bankName, System.Boolean loadSamples) [0x00000] in <00000000000000000000000000000000>:0
2022/08/18 00:13:30.301 6442 6464 Error Unity   at FMODUnity.RuntimeManager.LoadBanks (FMODUnity.Settings fmodSettings) [0x00000] in <00000000000000000000000000000000>:0
2022/08/18 00:13:30.301 6442 6464 Error Unity   at FMODUnity.RuntimeManager.Initialize () [0x00000] in <00000000000000000000000000000000>:0
2022/08/18 00:13:30.301 6442 6464 Error Unity   at FMODUnity.RuntimeManager.get_Instance () [0x00000] in <00000000000000000000000000000000>:0
2022/08/18 00:13:30.301 6442 6464 Error Unity   at FMODUnity.RuntimeManager.GetBus (System.String path) [0x00000] in <00000000000000000000000000000000>:0
2022/08/18 00:13:30.303 6442 6464 Error Unity BusNotFoundException: [FMOD] Bus not found 'bus:/Music'
2022/08/18 00:13:30.303 6442 6464 Error Unity   at FMODUnity.RuntimeManager.GetBus (System.String path) [0x00000] in <00000000000000000000000000000000>:0
Solved! I’m not sure why, but the banks would only load with Split Application Binary enabled. For anyone troubleshooting, I guess going for the low hanging fruit could save a lot of time. :sweat_smile:
