Hello, i’m having build errors when packaging a project for Android.
I’m running 4.27 and my FMODStudio folder is INSIDE of the game’s Plugin folder. Validated correctly when running the tool in the editor. The project builds fine on Windows however I get an error when packaging the APK it seems like. here’s the log snippit:
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): > Task :permission_library:generateDebugRFile
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): > Task :app:processDebugResources
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): > Task :permission_library:compileDebugJavaWithJavac
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Note: Z:\permission_library\src\main\java\com\google\vr\sdk\samples\permission\PermissionFragment.java uses or overrides a deprecated API.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Note: Recompile with -Xlint:deprecation for details.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): > Task :permission_library:bundleLibCompileToJarDebug
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): > Task :app:compileDebugJavaWithJavac
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): The following annotation processors are not incremental: lifecycle-compiler-2.0.0.jar (androidx.lifecycle:lifecycle-compiler:2.0.0).
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Make sure all annotation processors are incremental to improve your build speed.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Z:\app\src\main\java\com\epicgames\ue4\GameActivity.java:3180: error: package org.fmod does not exist
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): org.fmod.FMOD.init(this);
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): ^
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Z:\app\src\main\java\com\epicgames\ue4\GameActivity.java:3776: error: package org.fmod does not exist
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): org.fmod.FMOD.close();
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Note: Some input files use or override a deprecated API.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): 2 errors
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): > Task :app:compileDebugJavaWithJavac FAILED
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): FAILURE: Build failed with an exception.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): * What went wrong:
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Execution failed for task ‘:app:compileDebugJavaWithJavac’.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): > Compilation failed; see the compiler error output for details.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): * Try:
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): * Get more help at https://help.gradle.org
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): BUILD FAILED in 30s
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): 39 actionable tasks: 18 executed, 21 up-to-date
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): ERROR: cmd.exe failed with args /c “C:\Users\tyung\wkspaces\Super Hamster Havoc_2\Intermediate\Android\armv7\gradle\rungradle.bat” :app:assembleDebug
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): (see C:\Users\tyung\AppData\Roaming\Unreal Engine\AutomationTool\Logs\C+Program+Files+Epic+Games+UE_4.27\Log.txt for full exception trace)
UATHelper: Packaging (Android (Multi:ASTC,DXT,ETC2)): AutomationTool exiting with ExitCode=1 (Error_Unknown)
PackagingResults: Error: Unknown Error
Error in question:
Stuck on this one so any help would be super appreciated.
