Hey guys. Does anyone know how to set up FMOD in Unity for WebGl/Html platforms? I tried doing this a while ago and FMOD support said something about setting the DSP blocks from 4 to 2. They sent some sample code that has basically sent me down several rabbit holes of basic understanding of how everything works under the hood. I don’t mind spending some extra time connecting the dots, but I feel like it might be overkill for something that is close to a ‘set it and forget it’ situation.
This is part of the explanation and the sample code I received, but doing searches through the scripts has sent me down rabbit holes: Audio Stability (Stuttering)
Some devices cannot handle the default buffer size of 4 blocks of 1024 samples (4096 samples) without stuttering, so to avoid this set the buffer size in your application to 2 blocks of 2048. Here is an example
result = gSystem.setDSPBufferSize(2048, 2);
CHECK_RESULT(result);
I’m looking for more of a step by step thing, like:
- Put this code in script whatever.cs on after line (random number)
- Go into the settings of (tab of software) and click this button
- Whatever Else
- You’re all set, all known HTML stuttering issues should be resolved
Thanks
