Press F7, go back to unity and nothing has changed, turn on live update the then the changes happens. I’m on Mac Catalina. Unity 2021.3.4f1. Fmod 2.02.07 Is this a known issue? If not can it be related to the Fmod package being 08?
Best
J
Best
J
Unfortunately, I was not able to recreate the issue.
Could I grab a bit more information:
Hi Connor
Thanks for your reply.
Is there anything special about where your FMOD Studio project / Banks are located? e.g In your Unity project’s Assets folder, on a separate hard drive, in a cloud linked drive
Both projects are on the same drive. I’ve also had the same problem if I nest the Fmod project in the Unity folder (not in Assets).
Are your banks being tracked in source control?
No.
- What is the Built Banks Output Directory of your FMOD Studio project, and does it match with the [Build Path] in your FMOD Unity settings?
Default Fmod project folder and yes it’s the same as under Fmod settings in Unity.
If I start a project from scratch I can get it to update but only after I specify the banks and refresh from within Unity. See vid below.
Fmod build update issue
I suspect this has something to do with Macos Catalina because I don’t see the same issue on the M1.
Thank you for the video.
Again I was unable to recreate the issue.
Is it possible to get a copy of the FMOD and Unity projects to test on my end? You can DM me a repo or a cloud drive.
Also, could you test whether Live Update is working when you have your Unity project running? Check if it is throwing any console errors.
